Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Perguntas Visualizar todos
Is there any guide for change thermal paste?
HI there,
newbie have a question.
1. How & when we should change thermal paste ? i read some article said that we need to change thermal regularly, is it true ?
2. is there any guide that showing step by step to change thermal paste ?
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Its never a bad idea to replace thermal paste . This video can help with the process . Also don't cheap out on the paste quality
Esta resposta foi útil?
Pontuação 2
I agree with @jimfixer that changing the thermal paste is a good idea. The i7's can get pretty hot if you are doing some high end activities, such as gaming, graphics editing, or even simple web pages full of Flash. I suggest Arctic silver. You only need a thin layer with that. The idea is to get as thin a layer as possible to transfer the heat directly from the processor to the heat sink instead of heat getting trapped and built up in the "grey goo" first.
Pontuação 2
1: There is no need to change thermal paste in the whole expected life of the device (3 years). If you want to use the machine for more than 5 years, change it then.
2: Apple has official repair manuals for thermal paste changing, but they are just being through. You shouldn't have to read a manual to change some grey goo.
Pontuação 1
Adicionar a sua resposta
yogie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 215
