Ir para o conteúdo principal
O Dell Dimension 3000 foi um desktop de médio porte lançado em 2004. Ele vinha com 2 GB de RAM e opções de processador Pentium 4, 4 HT ou Celeron.
cpu fan stops turning
My cpu cooling fan needs a manual boost to start turning. What will a remedy be.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Herman Moothery , If you find yourself having to prod the fan to get it to spin, replace the CPU fan as it is sticking and probably faulty/worn out, new fan is inexpensive insurance to keep the CPU cool. Link below is just an example of a new fan that can be purchased, you can also do a search for perhaps better pricing. Good luck.
http://www.ebay.ca/itm/like/371612158491
Esta resposta foi útil?
Pontuação 3
It depends, some CPU's do not get hot in standby so the fan does not start turning until a specific degree of tempreature is reached. Then it is normal. But if the Fan is older then I would just buy a new CPU fan and then you can also choose to get a more quit version. There are a lot of CPU coolers out there.
https://geizhals.eu/?cat=cpucooler
Pontuação 2
Adicionar a sua resposta
Herman Moothery será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 890
