Ir para o conteúdo principal
iPhone 6S showing No Service After Housing Replacement Not Blacklisted
Hi,
I would much appreciate if someone could help me with this one.
I do housing replacements for a long time now. I this time haven't tested the phone carefully before I made a replacement. It catches signal for 5 mins, then it suddenly starts showing no service for 4-5 secs, then the signal comes back on.
I replaced the charging port flex with a new one, then replaced the tiny ribbon that goes from the motherboard to the camera (at the top right), then cleaned with 99.9% Isopropanol the antenna bracket, checked the screws lengths on that side, on the top left corner, performed a restore and the problem is still there, goes to no signal every 5 mins.
What else I can do? I belive this is the hardware level problem, where the components that may cause the no signal issue? The motherboard looks undamaged. Please help.
Many thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There is an Antenna Wire on the new Charging flex cable - Make sure this is connected -
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you, this is firmly connected, I also checked the connector on the board, which looks undamaged.
por
Adicionar a sua resposta
Olena Scukina será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 146
