courtesy light stays on while driving
interior light stays on while driving. doors closed
Esta é uma boa pergunta?
Hi,
1. Verify that the courtesy light switch is in either the off or door position not the permanently on position.
2. Possible faulty door switch. (switch located in rubber boot in door frame, every door).
Try opening each door, one at a time, locate the switch and manually press the switch closed to see if there is any change at all to the light, even a flicker
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,851
