Ir para o conteúdo principal
Lançado em 22 de novembro de 2005, o controle sem fio Xbox 360 é o principal controle de jogo para o console de jogo Microsoft Xbox 360.
My Xbox 360 wireless controler wont do anything.
So I got a used Xbox off Craigslist and some of the remotes had battery acid corrosion on them. So I clean them with lemon juice and now nothing happens when I try and turn them on nothing happens. NOTHING!!!!! Please help!!!!!
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Were are the battery contacts and how do I know if they are bad? Does it make a difference if I'm using AA's or not?
por
Yes you need to use aa batteries, along with the battery shell that the batteries fit in to. The contacts are just the metal part where the batteries sit on top of. Make sure they are not corroded or bent otherwise the controller won't be getting power from the batteries
por
Ok how do i know if the battery contacts are bad
por
Adicionar um comentário
1 resposta
Hi you would need to dismantle the controller and clean the battery contacts with isopropyl alcohol and a toothbrush, if they are really bad and that doesn't work, then you would need to buy replacement ones
Esta resposta foi útil?
Pontuação 0
1 comentário:
The battery contacts are the metal part where the batteries sit and if they look corroded then most likely you would need to purchase replacement ones and solder them on
por
Adicionar a sua resposta
Parker Collins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,376
