Wont Charge, No charge light
Hi,
My JBL flip does nothing when plugged in. No charge light and will not charge. I assume it is the power plug or the connection.
TIA
Esta é uma boa pergunta?
Hi,
TIA
@congressmankml, Congressman Kamal EL, Try charger in another outlet, test or have charger tested or if possible try another compatible charger. If charger is fine, then it could be the charge port or needing battery replacement. Look in the devices charge port for dust/debri and clean out(blow out with canned compressed air). Wiggle the cable at the charge port end and note whether the port seems loose or starts charging(this would signify port may need resoldered or replaced) best done by good technician. If all looks OK, battery may need replaced. See links below for tear down and general trouble shooting.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 9,927
