Ir para o conteúdo principal
Projetada para oferecer resultados profissionais em um pacote compacto, a J1 vem em uma variedade de cores e encaixes de lente.
Broken Battery clip replacement
The tiny yellow clip that holds the battery in my Nikon J1 has broken. I would like to know how to fix it and what that part is offically called
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
This little plastic part could be actually bought for around $10 from a seller on eBay. But looks like it is out of stock now. The part number is 1K684-884.
Alternative solution: buy the extension grip Nikon GR-N2000 or its Chinese knock-offs available on AliExpress. They might help, as they should press strong enough against the battery door and keep the battery in place.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for your advice
por
I just replaced my battery catch , a part I ordered from AliExpress for £13. Patience is needed using watch makers tools took about 1 hour. After studying how and what to remove
Pontuação 1
1 comentário:
cannot get to find any hints on the web, but it seems that you need to disassemble everything
por
Adicionar a sua resposta
Tiffany Love será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 1,085
