Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Is there any specific compatibility problems with replacing the HDD?
I recently acquired a PowerBook G4 17" M9689LL/A, A1107 to repair.
From past experience with the device I know the HDD in it has gone and ideally needs replacing. I keep hearing reports from people that it will only accept certain makes and models of HDD. I was wondering if anybody knew if there was any truth behind these rumours, or if I could put any 2.5" IDE HDD in to it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You can put in any IDE/PATA HDD inside. There would be no reason why it wouldn't work.
Here are some IDE 2.5" drives to pick from
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jake Stevens será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 768
