Brake light stop working
Brake light stop working on my truck i put a fuse in it and hit the brakes and it blew put other one in and it done the samething what do i do
Esta é uma boa pergunta?
Patricia Holloway, If your brake light fuse is blowing every time you press the brake pedal there is a dead short in the brake light circuit between the switch and the bulbs. The wire harness must be traced to find the short. Try a visual inspection, you will be looking for any damaged,bare,pinched,burnt(melted insulation) on wires,plugs,sockets and also check/test bulbs. Pay special attention to any where wire could be rubbing on metal frame, taped up joints/connections, etc.. If there is a trailer light harness with converter, especially if a add on one you may want to disconnect it as they can be problematic and cause this issue. If not comfortable working on your vehicle take into a good shop and have them diagnose and estimate repair, most good shops have hand held short finders(link below) and can find the problem fairly quickly. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 91
1 comentário
Hi, Does it only happen with the brake lights or do you blow a fuse with the tail and turn lights as well?
Have you got trailer wiring connected at all?
por jayeff
