Where does spring go?
where does spring go in manual stapler
Esta é uma boa pergunta?
Eric Fields , I assume you are asking about the long thin feed/load spring which usually connects to a small tab on the staplers upper slide housing and to a tab on the slide. The links below should help you out in seeing spring mounting locations. On the guide link once you have opened it you can zoom in on where the spring is attached. Good luck.
Esta resposta foi útil?
here we describe everything ..
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 107
Ao todo: 44,570
2 comentários
Where can I buy a spring for a nematic staple gun thanks Mary
por Mary Fallon Compartilhar
This doesn't work for swingline 444
por Izaakraaaaay Compartilhar
