Ir para o conteúdo principal
Como desmontar e reparar a Panasonic Lumix DMC-FX01.
Why is my LCD yellowish?
my lcd looks yellowish and too bright. may i know what could have happen?
Update
Updated
Imagem
Esta é uma boa pergunta?
Pontuação 2
3 comentários
the camera dropped once and the lcd cracked, i've change the lcd. it works but lcd is yellowish. is it possible for me to send an image to let u see it?
[image|81792]
por
the lcd works on the on other camera.. but not mine. could it be something wrong with the circuit board or lens?
por
Has the camera suffered any physical damage?
por
Adicionar um comentário
1 resposta
Solução escolhida
I would re-check the connectors for the LCD screen. If they are fully secured and the LCD screen still doesn't display correctly, there may be a problem with the LCD you purchased.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
saosin matchbook será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 3,736
