service engine soon light
how do I reset' Service Engine Soon' light
Esta é uma boa pergunta?
@scull801 , Steve, Turn ignition switch to on without starting the engine. Press the options button on the instrument panel until the service light is displayed, then press reset/set button to show the reset confirmation screen.
Turn ignition off. Repeat if message comes back.
Use the links below for more info.. Good luck.
https://www.youtube.com/watch?v=FF9e44tQ...
Esta resposta foi útil?
The "Check Engine" or "Service Engine Soon" light indicates there may be a repair or replacement of your engine or transmission. It means there is more than a routine repair or service requirement, and instead, a system failure to the fuel, transmission, ignition, or emissions.
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 38
Ao todo: 18,137
