Ir para o conteúdo principal
O Moto X de segunda geração (comercializado como moto X) é um smartphone Android desenvolvido pela Motorola Mobility. Lançado em 5 de setembro de 2014, ele é o sucessor do Moto X original, lançado em 2013. Números de modelo XT1097, XT1096, XT1095 e XT 1093.
Overheating after screen replacement
So this will be the second Lens/LCD assembly we've ordered for this device due to the first replacement screen cutting off randomly and getting hot while turned on/charging/post testing device. So we ordered a new Lens/LCD assembly expecting a defective part on the first go. Round two, I've made sure to move all the protective tapes from the old screen to the new assembly and any other pieces of components that were in the old screen but not the new one. The phone is still heating up pretty seriously and cutting off from time to time after everything is put back together. Am I missing an important step that's causing a bad ground resulting in the overheating issue? At check-in, the receptionist made note of slight heat coming off of the device in its original condition, although the customer vehemently says overheating was never an issue. Anything would help. Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
refund customer and install their old screen. hold your ground about the phone being hot when brought in. stay calm even when customer gets angry, easier said then done but at this point, it's not your fault, unless you bent the board when taking it out originally and damaged something under the emi shielding. if you did not then you're trying to avoid a negative review and hope the customer still keeps faith in repair.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Steve B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 470
