Ir para o conteúdo principal
Colorful vertical stripes on iPhone screen
Hi,
My iPhone 6 screen suddenly started displaying colorful vertical stripes (photo here), but the touch is responsive. I have tried restarting and resetting the phone, but there must be a hardware issue.
I have also tried opening the phone and making sure the screen connectors are not loose. Took it to a local repair store and the guy told me that the "graphics IC" is broken and needs to be replaced. But apparently there is no such thing as the graphics IC in iPhone. Does anybody know what needs to be replaced?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Has another screen been tested on there?
por
No, could it be the screen?
por
It might be touch disease
por
No this is probably not "touch disease". I googled it and two main symptoms are the gray bar at the top of the screen and unresponsive touch, neither of which is present in my phone.
por
Adicionar um comentário
5 respostas
Solução escolhida
iPhone 6 LCD and Digitizer
Substituição do conjunto do painel dianteiro do iPhone 6
Imagem de iPhone 6 LCD and Digitizer
Produto
$69.99
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Its Display Problem
Replace New Display
Note ; There ll Be No Issue with Graphic Ic or anyother things
Hope It Works
Thanks
Varun
Pontuação 2
Please try to replace the display, you could have a bad LCD or it could be damage on the LCD connector on motherboard. But i would try to replace LCD assembly first .
Pontuação 1
He only want to charge you big bucks $$$ for something that isn't broken, just put a new screen first.
Pontuação 1
Thanks a lot everyone, I'm definitely gonna try a new screen first. I'll report the result.
Pontuação 0
1 comentário:
can you put the result ? it will help me a lot to figure out something.
did it works when you replace the screen?
Thanks
por
Adicionar a sua resposta
Alireza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 23,501
