Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Activation problem iPhone 5s
I keep trying to activate iPhone did everything from hard reset to plug into iTunes over and over... The iPhone take you through all the activation steps to set up to the welcome to iPhone. I press get started and iPhone then goes inside the iPhone for like one second then black out goes back to Hello screen and then Activation Required pops on screen.. On iTunes it says iPhone can't be activated try again later.. Has anyone ever incountered this problem before?? Someone please help...
Esta é uma boa pergunta?
Pontuação 1
7 comentários
Does It Have A Sim Card In It?
por
try activating through iTunes if there is a baseband firmware issue then iTunes should recognize this in the restore process. the cpu sn. modem sn baseband memory or nand sn can cause activation issues
por
you can also download 3utools this will show you in the main window the capacity of memory, base-band firmware and iemi this tool also enables you to reflash but be aware the flash process could brick your phone but will identify the cause
por
Yes it has a SIM card and I've tried everything over and over in an attempt at activating the phone don't know what's going on???
por
Can you find the way to solve the problem so far? The problem occurred to me today. I tried everything and already read lots for forum about this but still can’t figure out how to fix it ..
por
Exibir mais 2 comentários
Adicionar um comentário
3 respostas
Solução escolhida
I'm surprised nobody ask this but do you actually see an IMEI number displayed when you tap on the blue circle i icon on the setup lock screen?
Sounds like the baseband chip needs to either be replaced or reballed.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Yes, in my case the IMEI no. did show up.
I firstly thought it was a software problem. I don’t have time to actually take it back to the store yet but seemed that I have to do so if it is a problem with hardware.
Thanks for pointing out anyway.
por
Take out any sim card in it. Connect it thru Itunes or 3 u tool and just flash it.
Pontuação 1
What is your iOS version. I heard of that if iPhone 5s on iOS 11+, it could not be activate. You can aslo try to activate your iPhone with 3uTools.
Pontuação 0
Adicionar a sua resposta
Charles será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 2,970
