Activation problem iPhone 5s
I keep trying to activate iPhone did everything from hard reset to plug into iTunes over and over... The iPhone take you through all the activation steps to set up to the welcome to iPhone. I press get started and iPhone then goes inside the iPhone for like one second then black out goes back to Hello screen and then Activation Required pops on screen.. On iTunes it says iPhone can't be activated try again later.. Has anyone ever incountered this problem before?? Someone please help...
Esta é uma boa pergunta?
7 comentários
Does It Have A Sim Card In It?
por Justin R
try activating through iTunes if there is a baseband firmware issue then iTunes should recognize this in the restore process. the cpu sn. modem sn baseband memory or nand sn can cause activation issues
por tonyhamre
you can also download 3utools this will show you in the main window the capacity of memory, base-band firmware and iemi this tool also enables you to reflash but be aware the flash process could brick your phone but will identify the cause
por tonyhamre
Yes it has a SIM card and I've tried everything over and over in an attempt at activating the phone don't know what's going on???
por Charles
Can you find the way to solve the problem so far? The problem occurred to me today. I tried everything and already read lots for forum about this but still can’t figure out how to fix it ..
por Pat Khumprom
Exibir mais 2 comentários
