Ir para o conteúdo principal
Guias de reparo e suporte para tablets fabricados pela Azend/Envizen.
SIMM card inside the tablet
The small inter part of the SIMM card broke off in the slot. What can I do to get it out?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
It's hard to say without being able to see it. I usually utilize a pick (VERY CAREFULLY) to try to pull the card out. Is it visible enough for you to take a picture?
-CW
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thank you so much for the information but the small card is not visible. You need a small flashlight because it at the bottom. The Geek Guy said he would need to take the back off.
por
Without a solution, I took it to the Geek Guys. They took off the back and took out the card. What a rip off. $20 to take off the back and investigate the problem then another $20 to remove the card. I will try to solve the problem myself next time with a pick.
por
If you do, just make sure that once again, you are extremely careful.
por
Adicionar a sua resposta
Jtourre será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 603
