Ir para o conteúdo principal
iPhone 6 plus Touch Disease Repair Attempt Failure
Before any repairs, a piece of the battery connector fell off by itself. This strangely did not appear to affect the phone since it still turned on. I attempted to repair touch disease on my iphone 6 plus by replacing the smaller silver chip on the board. After replacement, the iphone 6 plus still did not have touch. I began to suspect the screen was simply seated incorrectly and I reseated the screen many times. After a few times, the screen turned blueish and slightly flickered if you looked very closely at it. I kept trying to get it seated properly and eventually the screen doesn't even turn on anymore! At this point im unsure if its the connector for the screen, the battery connector, or the touch ic chip i had replaced. I have only tried using a heavily water damaged screen on it and a "brand new" screen on ebay. I figure it cant be only the screen because both screens now appear completely black.
What should I do now?
The phone still connects to computer
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Update: now it turns on again with the weird blueish screen
por
Adicionar um comentário
1 resposta
I was going to upload a video walking through what to test but ifixit is retarded when it comes to uploading media.
I would recommend taking the new ic you installed off and powering the device on with no new cumulus broadcom chip installed. It should power on without the chip. This will let you know if the chip was installed correctly or if you accidentally bridged pads.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Hi @mdrecovery
Just for my info, what happens when you try to upload media? I have never had the chance to upload videos only pictures etc. using the insert an image or video option. There is a media option in there so I'm wondering what happens?
por
You're unfortunately limited on the size of the video. Plus loading a video, even compressed, takes what feels like an entire evening.
por
Hi, Thanks for that. Something to remember.
por
Adicionar a sua resposta
Diego A será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 580
