Ir para o conteúdo principal
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
Screen Replacement for P55w-B5220
Thank you in advance.
I need a replacement for the screen both the lcd and the touch panel., where can i get them.....
looked in ebay and amazon and didnt fine any...
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
Here you go...
http://www.ebay.com/itm/Toshiba-Satellit...
It may be cheaper to just get a new laptop.
Esta resposta foi útil?
Pontuação 4
2 comentários:
Hey bro. Amazon has the entire screen for around 200us. Be very careful when using a flat screen removal tool around the corners of the display where you will see a thin gap. I had to figure it out my self since they weren't any video on YouTube yet
por
@gilcom You do realize that AT THE TIME THIS WAS ANSWERED, screens totaled these out right? This is an OLD POST.
por
I have the same issue, here is what i found so far:
http://www.lcds4less.com/toshiba-satelli...
Pontuação 1
1 comentário:
Can you give me directions on how to remove the screen for Toshiba Satellite radius p55w-b5220 screen?
por
i have toshiba P55w-B5220 touch screen and its screen changed to pink i check all the cable connected to screen but fail what i have to do please need suggestion.
Pontuação 0
1 comentário:
check for screen connection prongs that are bent on not seated fully
por
Adicionar a sua resposta
Tammam Alzaidi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 7,216
