Ir para o conteúdo principal
Guias de reparo e suporte para a linha de câmeras Fujifilm FinePix.
camera will not power on why
is a finepix j110w will not power on, have new batteras it still will not power on?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
waddell68 . Remove the battery and memory card from the camera, clean your battery contacts with ink eraser on a pen/ clean cloth/Qtip and then blow out any dust/debri. Install new good quality batteries in ((correct orientation)) and try powering up camera. If camera does not turn on, problem could be with internal switch connection or the main circuit board bad. You could disassemble the camera clean all the connections and secure them. If not comfortable opening camera have a good camera shop have a look, diagnose and estimate repair. Find below a link to your cameras manual, check through their trouble shooting section,etc.. Good luck.
http://www.fujifilm.com/support/digital_...
Esta resposta foi útil?
Pontuação 1
I have the same problem with my S2900 Finepix.  Camera will not power up when AC adaptor kit fitted.  Any help would be appreciated.
R
Pontuação 0
Adicionar a sua resposta
waddell68 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 57
Ao todo: 3,075
