Ir para o conteúdo principal
Guias de reparo para o MacBook Air, a linha atual de laptops da Apple.
4820 Perguntas Visualizar todos
Exchange SSD from old MacBook air 2011 to 2015
Are there any differences between SSD (mSATA) from macbook air 2015 (MacBook Air 13" Early 2015 SSD Replacement) and that of macbook air mid 2011 (MacBook Air 13" Mid 2011 Solid-State Drive Replacement). I just want to swap the old SSD onto my new macbook air. I do not care about speed or such things. The old macbook air mid 2011 already has El Capitan, Are these compatible?
Imagem de MacBook Air 13" Mid 2011 Solid-State Drive
Guia
Nível de dificuldade:
Moderada
20 minutes
Imagem de MacBook Air 13" Early 2015 SSD
Guia
Moderada
10 - 25 minutes
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
No they are not compatible. For the MacBook Air;
2010-2011 compatible with each other
2012 only works on a 2012
2013-2015 compatible with each other
Esta resposta foi útil?
Pontuação 4
1 comentário:
Correct! They are not interchangeable between your models. +Reece
por
What you can do is take the SSD out of your older system and place it into a special case so you can copy off your stuff or use migration assistant if your old system is dead. If your older system is working you can interconnect the two systems to either copy off or use migration assistant using Target Mode.
Pontuação 1
2 comentários:
@danj Thanks but not what I asked in the question!
por
The point was to give you some options as Reece had already answered! You'll see I even commented as it being correct to support his answer (plus upping his score).
por
Adicionar a sua resposta
Edward C será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,275
