Ir para o conteúdo principal
Informações e guias de reparo para modelos de MacBook Pro com telas de 13 polegadas.
9745 Perguntas Visualizar todos
Camera not working. No hardware found.
After tearing the whole Mac apart and putting everything back the camera hardware can't be found.
I never had this problem before, always careful with everything.
Maybe the camera was already broken, don't know and don't want to ask the customer yet.
Got the cable out of it socket 3 times now but no go.
Also attached my external hdd with OS X to see if it's not a software problem but still the same.
Mac came to me because of overheating and a dying fan.
Anyone an idea for what to try next?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I'm assuming you've already done SMC and NVRAM resets, and you've also reseated the connectors.
I would assume that the camera module is dead as a first hunch. When dealing with the small camera assemblies, especially in iPhones and Macs, it's easy to overbend the camera ribbon cables and break one small trace.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I've looked in the logs. Seems like the camera hasn't worked for a while.
I'll ask the customer tomorrow.
Thank you for your response
por
Adicionar a sua resposta
Nathalie Spoor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 300
