Ir para o conteúdo principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Cannot send text why?
My phone works well other being able send text messages
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Thank you that fixed problem
por
Good. I'm glad I could be of service. At your service night and day, if I don't fix em' you don't pay! (You don't pay anyway.)
por
Adicionar um comentário
1 resposta
Solução escolhida
Have you done a restart? If not, hold down the power button for about 3 seconds and touch restart. If you have done this already, try doing a system reset. A system reset will return the phone to the way it was when it left the factory. It will delete everything on the phone, so make sure anything important is backed up. A system reset, or sometimes called factory reset, is good for a phone once in a while, so to do a reset go to settings and find backup & reset, then choose factory data reset. This should fix your problem. I hope I was of assistance.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Did this solve your question?
por
Adicionar a sua resposta
Bob Rolls será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 92
