Ir para o conteúdo principal
Guias para o tablet Sony Vaio Tap 11. Anunciado em 4 de setembro de 2013 e lançado em 18 de outubro de 2013. Número do modelo SVT112A2WL. O primo fino, elegante e atraente do Surface Pro 2.
Where is the CMOS battery?
My system clock keeps on delaying compared to the actual time.
Is there a repair?
I also noticed that it may be caused by the CMOS battery starting to fail.
I have opened the device up and am comfortable, as I replaced the mSATA myself.
However, I don't really know where the CMOS is.
Where is it? Thanks
Update (01/01/2017)
Imagem
Tried to locate it in the area, but it looks like it isn't really there.
It's only cables that connect the circuit board.
Also, I purposefully disconnected this part that is mentioned in the instructions for motherboard replacement and speaker replacement. The computer turned on and wifi was completely functional with it disconnected. What is it for?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
akihiko1639 post some clear images of your complete board (may take multiple shots) and post those with your question.
the connector is for your speakers.
por
Adicionar um comentário
1 resposta
Solução escolhida
Imagem
Imagem
The blue bit that can be seen is probably the RTC battery.
The images were taken from the Vaio Tap 11 teardown by Sony on Youtube.
Hope it helps!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
akihiko1639 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 3,152
