Ir para o conteúdo principal
Lançado em janeiro de 2015. Smartphone Android.
Mobile dead after wrong software update through flash tool
Hi Team,
Last night after doing the fast boot my device has stopped working. The screen is not getting on, I tried to plug the charger but there's no notification light. I tried to remove the battery for few minutes and still no hope. I also tried to load fastboot once again by pressing Vol UP + Power / Vol Down + Power / Vol Up + Down + Power still no joy. The next step I did is I remove the battery then insert my phone to my Laptop then I plugged back the battery, it wasn't detected.
even i check the following thread http://en.miui.com/thread-100553-1-1.htm...
which needs a bit of technical skill....but there is no luck on that as well
I have read many threads on forums about MI Flashing, the problem is I can't load my device neither in fastboot nor detect my phone.
Request your help on the same from chip level to repair the hardware as u t the one in market to fixit this issue.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Hi Edward
Thank u for the sol.. can u please suggest me how to resurrect it! , what n where i should do it, to make it work.
por
Sadly, I too lost a phone by inserting battery _while_ the phone was connected to charger/power. Cant fix.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Do you mean you connected your phone without battery to laptop? And then while the phone was connected to laptop you inserted the battery? This would likely damage the main board due to surge in current.
Hope you can resurrect it! good luck and let us know if it works.
Esta resposta foi útil?
Pontuação 1
read here http://en.miui.com/thread-126437-1-1.htm... or
here https://forum.xda-developers.com/redmi-2...
Pontuação 0
Adicionar a sua resposta
Siva será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 3,494
