My TV has sound but no picture. Can it be fixed and how?
When I turn my TV on it has no picture only the sound works. Can it be fixed and how?
Esta é uma boa pergunta?
@tlortiz this could be related to a bad main logic board, power board or the backlight LED driver boards. First test you want to do is to shine a flashlight at an angle (TV on and at a known good station) See if you can make out shadows, that would mean that your backlight does not come on. You will have to remove the back of your TV set and check out a few boards.You do need a multimeter etc to work on it. Post some images with your question so we can see what you see. For that use this guide.
Esta resposta foi útil?
Okay, thanks!
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 16,054
6 comentários
@tlortiz not to insult you or anything but you made sure the volume was up and you checked on different video-in sources?
por oldturkey03
Yes, I was watching a movie and the picture just went out but the sound was still working.
por Toni
@tlortiz you checked your HDMI S-Video and composite video inputs as well? If so, sounds like your backlight is out....
por oldturkey03
Last night I went to turn my tv on and the tv didn't work so I listened to the back of my mams tv and I herd the sound but no picture what can I do
por William muers
If my TV has sound but no picture does that mean I need a new Television
por griesbachmartucci
Exibir mais 1 comentário
