Ir para o conteúdo principal
Smartphone topo de linha da Huawei de 2016. Possui corpo monobloco e um conjunto de câmera traseira dupla desenvolvido em parceria com a Leica. Disponível em opções de armazenamento de 32/64 GB e seis acabamentos diferentes. Números de modelo EVA-L29, EVA-L19 e EVA-L09.
touch screen not working after screen replacement?
Hi everyone! i have a big problem. I've just replace the screen of my huawei p9 (it has been a VERY HARD work), when i've finished all, i connect all the cable, i turn on the phone, the screen work but the touch screen doesn't. What happen? how can it not work? i've done everything right...
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
hi, have you solved? Did you understand what the problem is?
I have the same problem and I am very worried because the phone is not mine but my brother and he is convinced that the touch screen does not work because I have not been able to fix it. I do not want problems with him. Please reply
Esta resposta foi útil?
Pontuação 0
Resurrecting something from the dead here but I’m seeing issues with a P9 myself. Touch is working but occasionaly unresponsive to swipes (especially left-to-right) or misinterprets swipes as touches.
Googling leads me to believe there’s a grounding problem or something. Or perhaps the part is just bad. I’ll try insulating the screen from the frame and clean the pressure contacts to see if it helps and update this with any new info.
Pontuação 0
1 comentário:
Hi... Any update?
por
Adicionar a sua resposta
apriliamx5535 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 2,302
