Ir para o conteúdo principal
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
Hang at samsung logo
Hello , My samsung galaxy note II hang at samsung logo and i cant get recovery mode and when i trying to flash the phone from odin called me ( Fail ) i dont know what i do help me please
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Which stage on Odin does it fail at? I have had some cases where the cable was bad. Particularly some original Samsung ones because they got worn out from plugging in a lot.
por
I use original cable but i think its bad from the head
por
Adicionar um comentário
2 respostas
Solução escolhida
Not being able to boot recovery mode means the recovery partition in the internal memory of the phone has become corrupt / unreadable.
You may be looking at a board issue which is not fixable unless you replace the logic board and that would basically cost pretty much near the cost price of the phone 2nd hand.
You could try another cable and flashing it via ODIN again but I doubt it will work because the memory chip sounds corrupt / gone faulty.
I have had my share of a bad cable causing a flash to fail. If it is the original one you have been using for a long time I highly recommend another cable first before giving up on the phone.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Samsung Galaxy Note 2 boot logo
por
Pergunta mais útil
Hello, so sorry to hear about your problem. I am not really 100% sure what the problem could be but my first guess in this type of situation would be to think that there is some type of shortage in the battery. I would suggest trying a new battery and see if it goes all the way through. Hope this was of some help. Have a good day!
Pontuação 2
1 comentário:
If the problem from battary why i cant get recovery mode ?
por
Adicionar a sua resposta
abdulla muthana será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 5,540
