Ir para o conteúdo principal
O desumidificador Keystone KSTAD70A de 70 pints remove até 70 pints de umidade do ar por dia.
Reconnect float in collector tank
I dropped the collector tank and the float came out. Reconnected it with the male pin on the float into the opening on the collector. Can't figure out, however how to make the other side stay in place. Can't find the shroud or whatever that held it loosely in place to swing. So now the machine always thinks that the tank is full and therefore won't run. Any help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
There should have been a little plastic piece on each end to fit into holes. Do you think one of them broke off?
Mine just broke and I'm searching for a place to buy a replacement piece
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Michael Folloni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 348
