Ir para o conteúdo principal
The HP 7 1800 is a 7" Tablet made in 2013 by HP. It is a WiFi and Bluetooth enabled device with a 0.3MP front facing camera.
8 Perguntas Visualizar todos
How to fix a broken screen
The outside screen is fine be in the inside I can't see the screen it look like a crack in the inside.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi
Here is a link to the ifixit guide to replace your screen.
HP 7 1800 Display Replacement
Here is a link to just one supplier of the part. Perhaps you should verify with them that the part is compatible with your model before you purchase if you decide to use them. There are others online if this one doesn't suit you.
http://www.ebay.com/itm/New-LCD-Display-...
Alternatively, if there is a part number stamped on the back of the LCD screen in your tablet, search online using just the number to hopefully find suppliers of the part.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Alijah Frost será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 169
