Ir para o conteúdo principal
Cobra 29 LTD Classic. Rádio PX (CB) de 40 canais e 2 vias. Possui indicador de aviso de antena, calibração de SWR, canal 9 instantâneo, capacidade de PA, controle de intensidade, supressor de ruído selecionável e ganho de RF.
keys 4watts no forward swing
cobra 29ltd classic keys 4 watts no forward swing.new mic new final new ic chip tda2003 new driver
Update (12/21/2016)
I don't know about a d104 but the d11 has been removed by me it has no modulation so it will not swing forward
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
If it is not ic3 more than likely it will be ic1 pll chip .have had several with key up but no modulation output and it turns out to be the pll chip.
por
have you tried a different microphone
por
yes mic was good. I got it tr17 shorted thanks
por
Adicionar um comentário
1 resposta
Was the D104 diode clipped or removed? If not, remove the whole diode... If this is not removed, you won't get full modulation or watts. It must also be peaked to match the new driver and final.
This is just off the top of my head without you providing final and driver information, also assuming you upgraded the CB.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mark será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 1,269
