Ir para o conteúdo principal
Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
36 Perguntas Visualizar todos
lenovo y50 screen compatibility
first of all the reason am asking all these questions is because am frustrated i av bought two screens and back case for my laptop due to the flaw lenovo made when creating the touch version of their y50 and now my screen is broken again due to the hinge issue of always popping out the back case.
pls i want to find out if the lenovo y50-70 touch and non-touch make use of the same model or type of hinge
also i want to know if i can change my lenovo y50-70 touch the screen and back case holding the screen to a lenovo y50-70 non-touch version
and i believe the lcd cables are different so if am changing i will need to buy a new lcd cable for a non touch version.
pls will the screen be compatible if i change it thats from a touch to a non-touch version
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the service manual for a Lenovo Y50-70, both touch and non-touch models.
As it shows different part numbers for the hinges between the non touch and touch version you would have to assume that they are different.
Again with the back cover for the screen, they also have different part numbers for the touch and non touch models.
Scroll to p.92-95 to see an exploded view of the relevant components and their part numbers.
https://download.lenovo.com/consumer/mob...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ibhadogiemu Okougbo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 1,090
