Ir para o conteúdo principal
Laptop gamer lançado em 2014 com uma placa gráfica Nvidia 860M e uma tela de 15,6". Atualizado em 2015 com placa gráfica 960M.
How can I fix ethernet port?
This little part that keeps cable in the port is broken - it can't keep cable in position that computer recognizes ethernet cable. Is there any way to buy this little thing(this black thing with spring that is attached to ethernet port).
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
I think that this is the part that you are seeking.
Here is the Lenovo part number: 5CB0F78835
It is from the service manual for your laptop .
Here is a link to the manual. The part is listed on p.96 as RJ45 Door C Y50-70 etc.
https://download.lenovo.com/consumer/mob...
Here are some links to suppliers to give you an idea of the cost. There are others. Just search online using just the part number in the search box to get results.
https://lenovo.encompass.com/item/102030...
http://www.impactcomputers.com/5cb0f7883...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 6
Adicionar a sua resposta
Adam Dohojda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Ao todo: 7,050
