My screen is not working
When i switched on my laptop, the screen is malfunctioning as it splits into three different screen on the laptop. Is there a way to fix it myself?
Esta é uma boa pergunta?
@susu23 first you want to make sure that it is your LCD. Connect an external monitor and see what that shows. Should that show the same defect as your laptops LCD then you know that you are having a GPU (motherboard) issue. If the external shows a normal image, consider replacing your LCD. Take a look at this guide and this video. Combined you see how to remove and replace the LCD.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 702
