Reset to factory settings
When I reset my MiTravler back to factory settings it comes up all the time to input some codes ( numbers) in order to proceed, how to bypass and reset manually
Esta é uma boa pergunta?
leroysimpkins, from pg.17 of MiTravler manual.
Restore default setting, if you want to reset the factory setting and erase all materials, please press,
Settings → Backup & Reset → Factory data reset.
Link to manual below. Good luck.
Esta resposta foi útil?
what about the up/down key while pushing the on button
leroysimpkins, Yes you can try that it works on some devices, also note below,
From page #3 in your manual. Important Notice
-If the device is freezing or stuck, press the reset button(a small hole) or
long press power button for 7 seconds.
-When the performance is slow after using some applications, it is
recommended to close running application in setting menu.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 2,121
1 comentário
My mitraveler tablet is froze up need to reset it how do I do that
por Richard martinez
