Ir para o conteúdo principal
Tablet Tivax MiTraveler modelo 10Q-8. Sistema operacional Android 4.1 Jelly Bean.
Reset to factory settings
When I reset my MiTravler back to factory settings it comes up all the time to input some codes ( numbers) in order to proceed, how to bypass and reset manually
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My mitraveler tablet is froze up need to reset it how do I do that
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
leroysimpkins, from pg.17 of MiTravler manual.
Restore default setting, if you want to reset the factory setting and erase all materials, please press,
Settings → Backup & Reset → Factory data reset.
  • Warning: Factory data reset setting will delete your Google account information, data and configuration of system and applications from downloading.** Please use this function carefully.
Link to manual below. Good luck.
http://www.tivax.com/media/downloadable/...
Esta resposta foi útil?
Pontuação 2
2 comentários:
what about the up/down key while pushing the on button
por Compartilhar
leroysimpkins, Yes you can try that it works on some devices, also note below,
From page #3 in your manual. Important Notice
-If the device is freezing or stuck, press the reset button(a small hole) or
long press power button for 7 seconds.
-When the performance is slow after using some applications, it is
recommended to close running application in setting menu.
por Compartilhar
Adicionar a sua resposta
leroysimpkins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 2,556
