MacBook Pro dead because I connected ethernet cable
I was using my mac book when it went off suddenly. When i examined the laptop i realized the pins in the Ethernet ports had come together. I have separated the pins but it still wont on. at first, when u connect the adapter it was only green but i changed an IC and now the charger light indicates the battery is charging but the laptop does not on. Any Solution, where to look or what to do?
Update (12/04/2016)
http://www.everymac.com/ultimate-mac-loo...
The IC wasnt related to this issue.
My backlight wasnt work some months ago and I bridged the inverter IC for power because there was no power coming to it. So when this issue came up I replaced that IC with a new one from an old board and that was when the charger started indicating orange. Which mean the battery charges but the board doesn't power
Update (12/05/2016)
that is the board.
you can see the bridge with a thin wire.
Esta é uma boa pergunta?
4 comentários
Lets start off getting a bit more clarity on which model you have. Apple has produced quite a few different versions the MacBook Pro over the years so we really need to know which one to help you. If you can locate your systems serial number, plug it into this web site: EveryMac - Lookup. Then paste the systems URL here for us to see. If you know what year you have and the other details on what it came with you can also try giving us that info so we can figure it out.
As to what you did 'i changed an IC' can you explain which one and why.
While you may have had an issue with the Ethernet port connector it wouldn't have effected your system in the way you describe here. But it would be useful seeing what it looks like take a good set of pictures so we can see the damage clearly and post them in your question.
por Dan
There was no A1286, early 2012. There was a mid 2012.
por mayer
@donglory Clement - Can you fill us in on the rest here too. What was the IC you replaced? And why.
por Dan
@donglory, tell us more about this "I bridged the inverter IC" What and where did you "bridge"?
por oldturkey03
