Ir para o conteúdo principal
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
7 Perguntas Visualizar todos
Drive belt replacement, replacement parts
Where can I obtain a replacement drive belt for this unit?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
@cestrangio , Christopher use the links below, 1st link is Sony parts page where you could inquire about availability and the other links are belt suppliers that may have a suitable replacement for your M430. Good luck.
https://esupport.sony.com/US/p/model-acc...
http://www.thevoiceofmusic.com/catalog/t...
https://www.kenselectronics.com/lists/be...
http://www.gbaudio.co.uk/data/belts2.htm
Esta resposta foi útil?
Pontuação 3
4 comentários:
@lpfaff1 Wow I'm impressed you were able to find anything on something so old . Nicely done
por
@jimfixer , thanks Jim, and what about you where did you find that B code, I thought they only went up to B3000, good job on that one.
por
Hi @jimfixer and @lpfaff1
If ever you need belts here is one good resource for most belts. Although would you believe the one being asked about wasn't there!
http://www.russellind.com/client/downloa...
por
@cestrangio and just in case you need it, the Sony part number for the belt is 3-377-420-11
por
Adicionar a sua resposta
Christopher Strangio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 29
Duração total: 2,575
