Ir para o conteúdo principal
Netbook com processador Intel Atom N455 de 1,66 GHz, tela de LED de 10,1" e placa gráfica Intel Graphics Media Accelerator 3150.
How can I replace my hard drive?
How do I fix corrupt hard drive?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Make sure your laptop is completely turned off. Turn the laptop upside down, and located the sliding tabs on the battery. Slide the tabs into an inward position then take out the battery away from the laptop. Remove the bottom cover by pull the orange tab to the right until you heard a click sound. Gently disconnect the clips as you lift the bottom cover. Remove the four screws by using a Phillips PH1 screwdriver for the four black screws around the hard drive. Pull the hard drive towards the left using the orange tab until the hard drive is released from its receptacle. Replace your corrupt hard drive with a new hard drive for your laptop.
Esta resposta foi útil?
Pontuação 1
Nice instructions, I would go with an Ssd drive it will increase the speed a lot. Below are some different sizes and cost.
https://www.amazon.com/gp/product/B00OAJ...
https://www.amazon.com/gp/product/B01F9G...
Pontuação 0
Adicionar a sua resposta
Smitkumar Patel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 349
