Ir para o conteúdo principal
Informações de reparo para o Controle do Nintendo 64, número do modelo NUS-005. Este controle foi lançado em 1996, para uso com o console de jogo Nintendo 64.
Analog stick - Nintendo 64 Controller
Hi all,
My analog stick of mine controller is not working fine anymore. I found replacements on the internet. I found 2 different version.
Imagem
I got version A in my controller. Can I solder version B in my controller?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
From a bit of quick research, it appears that it should work fine. Just make sure that your pin connectors line up. Beyond that, it looks like it'll be okay to swap them out.
Best practice would be to install the new thumbstick and before closing it up, test out the controller to ensure that the new thumbstick reacts properly to the game.
Esta resposta foi útil?
Pontuação 0
I'd say it's a bit risky to add one of those into your controller, because if you got a warranty for it (IF YOU ONLY GOT IT A SHORT WHILE AGO that is) you have to hack into your controller to install the analog stick, and opening it up usually voids the warranty. Also, I've heard that the replacement analog sticks aren't exactly the best. Look in the video below
https://www.youtube.com/watch?v=o3GYtAyR...
Pontuação 0
Adicionar a sua resposta
Uas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 23
Ao todo: 1,165
