Ir para o conteúdo principal
Guias e ajuda para várias marcas e estilos de televisores (TVs)
99 Perguntas Visualizar todos
polorid flatscreen tv fadeing
how do i fix my poloid flatscreen. it starts to fade to white seconds after i turn it on
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@lilms650 what model is your TV? What have you checked? remove the back of the TV and post plenty of good images of the boards with your question. it will allow us to see what you see and help you further. Use this guide Adicionar imagens a uma pergunta já existente for that.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Often times, the capacitors in monitors and TV's that are in the power supply will go bad and cause the display to act up as soon as they have time to charge. If you take apart the TV and look at the capacitors (Probably the tallest cylindrical component) and see that they have a slight or large bulge in the top of them that means they are bad. In that case read the numbers on the side of the bad ones and replace them with an equal or greater valued capacitor. The metal part on the top of the capacitors should be completely flat.
Hope this works.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
laura será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 48
