Ir para o conteúdo principal
The HP Pavilion G6-2249wm is a 15.6-inch laptop in the G6 series.
Computer black screen caps lock key flashes and comp beeps
When I startup my computer it beeps then the caps lock key flashes while the screen stays dark. I have tried dissasembling and assembling again.
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Hi, Here is a link that describes the problem(s) depending on how many beeps and which lights are flashing. Use it to determine where the problem is and then get back here if you need more assistance.
http://h20564.www2.hp.com/hpsc/doc/publi...
por
I know about that page already but I'm a tech dunce so I don't know what they're talking about, as well the eg they give dont apply to my current problem.
por
Hi, Count the beeps, see if it is a sequence e.g 2 beeps pause 2 beeps pause etc, what is the beep code as you hear it, plus is it only the caps light blinking?
por
Adicionar um comentário
1 resposta
Finally fixed it don't know how all O did was dissasemble every piece and reaasemble it, except I still have a loud overheating fan even after cleaning it.
Esta resposta foi útil?
Pontuação 0
4 comentários:
Check what you did again to make sure everything is OK
por
I recommend changing the thermal paste under the heatsink for CPU.
por
@pyrojanus while you replace the thermal paste I'd go ahead and replace the fan as well. That way you do not have to continue to tear your computer apart....
por
Where can I buy thermal paste? Best Buy, or any hardware/computer store?
por
Adicionar a sua resposta
Janus Piro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 1,594
