Ir para o conteúdo principal
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
20 Perguntas Visualizar todos
How can I reset Parental Controls
I forgot the pin and the secret question. I tried calling them, but they said that the service was no longer available. WHAT DO I DO?
Esta é uma boa pergunta?
Pontuação 12
Adicionar um comentário
3 respostas
Solução escolhida
kdcao1 , 3 links below will take you through the process of resetting parental control if you have forgotten pin. and secret question. Good luck.
http://en-americas-support.nintendo.com/...
https://www.youtube.com/watch?v=_uvW3LZc...
http://xerohournix.blogspot.ca/2013/01/r...
Esta resposta foi útil?
Pontuação 19
9 comentários:
Thanks, the last one helped the most.
por
The last link was the best one, helped me reset a second-hand DSi easily. Thank you so much!!
por
Same, the last one was the one! Thank u so much!
Edit: I used this for a dsi xl and it was quick and easy.
por
Tried only the last one & it worked thnk U
por
the last link worked on my DSI XL
por
Exibir mais 4 comentários
THIS TOTALLY WORKS :'D It saved my boyfriend and I so much time. It worked with a DSi that he bought from a third party seller. This really helped out! Would recommend to someone else
I followed the comments and went right to the third link! I was confused at first because you need to set the DSi's date to the current date
Pontuação 1
The last one helped thank you
Pontuação 0
Adicionar a sua resposta
kdcao1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 42
Últimos 30 dias: 200
Duração total: 48,341
