Ir para o conteúdo principal
Guias de reparo e suporte para o ZTE n817, também conhecido como ZTE Quest.
How to fix LCD screen
I dropped my phone and the screen went white, but everything else still seems to work. The phone still viberates when I get a notification and the power button still works. The only thing wrong is the LCD screen. I want to know if something may have come unplugged and if so, what came unplugged. I may just need a new LCD screen
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Sounds like the LCD is done for. However try turning power off for a few hours while on charge and then turn power back on if screen still the same get a new LCD as swap it out
Esta resposta foi útil?
Pontuação 0
1 comentário:
it could also be a loose/disconnected cable. open up the phone and make sure all cables and connectors to the lcd are correctly in place
por Compartilhar
Adicionar a sua resposta
Grace será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 1,744
