Ir para o conteúdo principal
Down jackets wrap you in soft warmth, insulating your core from freezing temperatures and wind. They are highly compressible, extremely lightweight for their warmth, and ultra-comfortable for all day use.
40 Perguntas Visualizar todos
Zipper gets stuck all the time
Patagonia TorrentShell jacket
Zipper of my Patagonia TorrentShell gets stuck all the time. It stops in neck area when trying to get it closed. Fabric of inner stormflap gets stuck between zipper.
Has anyone tried to sew a some kind of reinforcement to stormflap? Maybe repair tape in flap will prevent it getting between zipper?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
villemitikka - I had this issue too and took my jacket to Patagonia - they ran 5 lines of stitching down the inside flap to stop it from snagging and it's worked perfectlyl. They have a free of charge repair or replace area in their stores.
Hope this helps!
por
John - Thanks for your answer. Sounds good and easy. Got to try stitching by myself.
por
Adicionar um comentário
3 respostas
Solução escolhida
Here's the guide on zipper repair for the Patagonia:
Installing A Main Zipper In Your Patagonia Down Jacket
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
villemitikka , I do not own this type of jacket, on a jacket that I had, did have this problem, so what I did when zipping up I would use my index finger to keep (guide) inner flap material away in the collar/problem area while zipping up. Worked for me. Good luck.
Pontuação 2
try using a old candle and run it up and down the zipper a few time to both sides of the zipper it will make it slide with ease
Pontuação 1
Adicionar a sua resposta
villemitikka será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 6,169
