Ir para o conteúdo principal
A décima geração da Ford F-Series é uma linha de picapes produzida pela Ford Motor Company, vendida entre os anos modelo de 1997 a 2004.
Shut off when in drive
When I start the truck it starts up fine but when I put it in drive it idles ruff then shuts off.. I have to keep gas on it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Jorge, Have truck scanned for trouble codes, some auto parts places offer code reading for free and may be a big help in diagnosing issue. It does sound like it could be a large vacuum leak. Check all vacuum hoses for cracks/loose/off. Use a can of starter fluid to spray around vacuum lines, intake manifold base gasket, throttle body, brake booster, etc. While spraying these areas listen for a change in engines rpm, it will change if there is a leak. Good luck.
Esta resposta foi útil?
Pontuação 4
I had this problem with my 2001 f150 lariat. the problem with was the mass air flow sensor (MAF) it would idle rough and cut off every now and then. I got some MAF sensor cleaner, removed it from the housing and changed the air filter for good measure. Sprayed down the sensor let it dry then re-installed the sensor. it hasn't done that since.
Pontuação 2
Adicionar a sua resposta
Jorge Francisco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 2,297
