Ir para o conteúdo principal
O Samsung Galaxy S5 Neo (SM-G903F) possui uma tela Super AMOLED de 5,1 polegadas com resolução Full HD. Ele conta com câmera dupla, sendo a traseira de 16 MP e a frontal de 5 MP. Equipado com processador Exynos 7580 de 64 bits, 16 GB de memória interna, 2 GB de RAM e bateria de 2.800 mAh, ele mede 142 x 72,5 x 8,1 milímetros e pesa 145 gramas. Em comparação com o S5 original, o Galaxy S5 Neo apresenta melhorias como câmera frontal, rádio FM e LTE mais rápido (Cat6).
How do you get into this thing
AAAAAARRRRGHHHH
Someone help how the heck do you get into this thing?
this has turned into a nightmare I'm replacing the dock port on this I've already busted the screen (glass just came straight off the LCD but thats a whole different story)
I have also removed the 13 screws from the frame under then screen but i cannot get all the casing off the other side to get into where the motherboard & dock port is.
I have undone the clips on the inside of the battery recess but it all is stuck down tight i don't want to force it too much this repair has already cost me big time
Someone PLEASE help & point me in the right direction
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@inthebox ,Kenny, Link to partial tear down of the S5 Neo and a 2nd link which may have more info., Good luck.
Substituição do display do Samsung Galaxy S5 Neo
http://www.sonymobilephones.com/samsung-...
Esta resposta foi útil?
Pontuação 3
2 comentários:
Hi Thank you for that i did see that but it only goes as far as taking screen out not going in as far as getting motherboard out. Someone was kind enough to come & show me how. Its deceiving it looks like it should come away from the outer frame thats what i was looking at & couldn't figure it out it actually comes apart inside.
por
@inthebox ,Kenny, thanks for posting back, happy to here you had success with your device. Have a good day.
por
Adicionar a sua resposta
Kenny Leonard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 553
