Ir para o conteúdo principal
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
iPod 6 Gen Screen Replacement
I have an ipod 6 Gen with a cracked screen. It works fine so I assume it's just the top layer of glass. Is it possible to replace just the glass and not the entire lcd screen? Also, I haven't been able to find a replacement glass part or lcd screen. Does it use the 5th Gen Lcd? I'm in Canada if anyone can point me in the right direction. Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
C Smith, It appears the assy. is advertised for 5/6 generation so I would imagine must be compatible. 1 st link is for display replacement instruction, other links are for display assy or just the glass to purchase, you can also do a google search to find more availability/pricing. Good luck.
iPod Touch 6th Generation Display Assembly Replacement
http://www.ebay.ca/itm/Replacement-Glass...
https://shop.icracked.com/collections/ip...
http://www.ebay.com/bhp/ipod-screen-repl...
https://www.aliexpress.com/popular/ipod-...
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
C Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 3,100
