Ir para o conteúdo principal
panic(cpu 1 caller 0xffffff8000a7b028b)
Hi, i google this panic error line, and keeps popping up, i replaced the HDD, and i get the folder missing icon with another macbook pro that i have, but when i try to boot again with the same HDD i get this error line.
heres a picture of the error
but its not the OS, i set that HDD in another macbook pro 13" 2010 and its good i can log in with no problem
heres my toughts:
the flex cable of the hard drive must be replaced, or the logic board must be replaced, but im not sure
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
"panic cpu 1 caller" Unfortunately your cpu or another they of chip is failing. Replacement of your logic board is probably your best option.
Esta resposta foi útil?
Pontuação 0
2 comentários:
So the cpu 1 it's related to logic board failures?
por
i have the same problem went to install a different hard drive give me the same picture but if i used the hard drive that comes with the computer don't happen so the cpu is ok
por
Adicionar a sua resposta
armandomh91 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 1,393
