Ir para o conteúdo principal
Tablet de 8,9" desenvolvido em conjunto pela Google e pela HTC. Lançado inicialmente em novembro de 2014, com o sistema Android 5.0 Lollipop.
The upper Speakers problem
Dear,ifixit team. Want to know my Nexus 9 tablet the dual front facing speakers only the downside one working which the upper upper one didn't make any sounds! Is it the speaker broken or the software problem?? Please help me out. Thanks and hope to hear from you soon.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Have you tried using earphones to check if there is audio in both L and R earphones?
If there is then most probably the internal speaker is faulty or has a loose connection.
Here is the Ifixit guide on how to access the speakers.
Substituição dos alto-falantes do Nexus 9
If not then perhaps it is a earphone socket fault, a motherboard fault, a speaker fault etc.
In any event the tablet will need to be opened so that the problem can be further diagnosed and then repaired.
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Woon Ping Ng será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 439
